Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2009 Ford Focus Clutch Problems
Old 11-11-2011, 03:00 PM   #3
KyleQ
KyleQ's Avatar
Fan#: 84296
What I Drive: 2008 Focus Coupe 5 Speed
Points 1,096, Level 17
Points: 1,096, Level: 17 Points: 1,096, Level: 17 Points: 1,096, Level: 17
Level Up 96% Completed
FF Reputation: 3 KyleQ Good Standing Member
Something sounds off - this transmission should have Ford MTX in it, aka Ford honey (~$7 a quart IIRC) Still - your "cold start" is nothing compared to what I describe a cold start in MN, no matter what, even with ATF (stupid PO) in the transmission it would shift easily in the winter. With Ford honey there is little to no difference in shifting between -10*F and 80*F.
It sounds like something is wrong with either the throw out bearing (TOB) or something internal.
Try this - if it is giving you trouble shifting into 1st, shut the car off. If it pops into gear after the car is shut off the clutch isn't fully disengaging - and you have a TOB issues. If the problem still continues with the car off, something is wrong internally inside the transmission.
2008 SE Coupe MTX
2000 Contour SVT 3L
MSDS Headers/Weapon-R Y-pipe
Torsen T-2/Clutchnet Stage 3
Fidanza 8lb 131 of 2150
KyleQ is offline
