Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2012 Focus Roushcharger!!!
Old 11-10-2011, 12:31 PM   #37
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
What I Drive: 2000 ZX3 / 2002 SVT Turbocharged
Points 68,295, Level 100
Points: 68,295, Level: 100 Points: 68,295, Level: 100 Points: 68,295, Level: 100
Forum Activity 99%
FF Reputation: 158 1turbofocus Excellent Standing Member 1turbofocus Excellent Standing Member
Buy-Sell-Trade Rating: (29)
Why is it everyone thinks Turbos are only for 400-500-10,000 HP , people think if you have 20psi boost that you drive around all the time with 20psi boost , it isnt th case
Superchargers for anything less then about a 4.0 engine are horrid , there worthless as we have seen with about every SC made for the Focus to date , small SC that you have to turn hard to work on small engine crete super high intake air temps , the pw and the jrsc are the worst , I have seen the intake air temps go over 250+ you would never see that with a intercooled turbo at the PSI that the SC is making
YES 100% of the time a turbo built for the same amount of boost a SC is built for will make more HP a TON more TQ and out perform the SC across the rpm range from 2000-7000
I have built a 10psi turbo kit that full spooled at 2800 and carried through 6000 very nicely then falling off and the IAT was about 18 deg higher then out side are , a SC would never do this
If you feel you need a SC for an application then you can do a Turbo that will do what you need even better , just dont put a 25psi turbo on if you need a max of 8-10 psi
Focus-Power: Your #1 Source for Ford Focus Speed, Tuning & Performance!
Customer Support
AIM: hpdyno
Email:
Phone: 704-249-3745
Site:
Elder 1turbofocus
1turbofocus is offline
