Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Help with datalogging
Old 11-10-2011, 09:47 AM   #17
Blivit
Blivit's Avatar
Fan#: 51292
What I Drive: 2013 ST
Points 2,359, Level 29
Points: 2,359, Level: 29 Points: 2,359, Level: 29 Points: 2,359, Level: 29
Level Up 40% Completed
FF Reputation: 118 Blivit Excellent Standing Member Blivit Excellent Standing Member
Originally Posted by svtf1417 View Post
Well I remember a couple times we stayed up past 10pm while you had control of my computer and trying to get this thing not to freeze up and I stumbled across a method that helped me out and hasnt stopped, but I know computers are all different.
1) Your going to need to have your laptop hooked up to the Xcal and the Xcal plugged into the OBDII port with the key on run.
2) Open Livelink, then open your saved livelink configuration. DONT connect to the vehicles ECU.
3) Go to commands and click "Configure Datalog Items". This will bring up all your PID's that your datalogging and the catagories will be expanded if your using a PID in that section.
4) Pick a PID that already has a check mark by it, un-check it, then re-check that same box and hit OK. In the bottom left it should say Setting Up or configuring or something along those lines.
5) Set up your analog equations and anything else you would normally do.
6) Enjoy datalogging again!
Again, this may not work for everyone but I encourage people having freezing issues to try it. I was sick to death of spending 4-5 hours a night in hopes that I might get Tom ONE WHOLE DATALOG a night.
Do you still have issues if you remove step #2? Meaning, take out the saved configuration file and select items from scratch. Open livelink with the device connect to the pc and the car with the key on. Select configure datalog items and select what you want to log then start the log.
Blivit is offline
