Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - ZETEC Engine stumble - SOLVED
Old 12-21-2004, 05:13 PM   #47
bwojdyla
bwojdyla's Avatar
Fan#: 3589
What I Drive: Red 2000 ZX3
Points 23,336, Level 93
Points: 23,336, Level: 93 Points: 23,336, Level: 93 Points: 23,336, Level: 93
Level Up 99% Completed
Level up: 99% Level up: 99% Level up: 99%
FF Reputation: 1 bwojdyla Good Standing Member
The PVC is on top of the oil seperator. look down at your engine, under the right side of the exhaust manifold is a rubber hose that makes a 90 into the top of the oil seperator (which is nestled up to the crankcase). That hose attches to the PCV valve, which supposedly just pulls out. I've never even been able to get the darn hose off to try.
To clean the MAF, first unplug it and take it out, as in out of its housing. There are two torx screws that hold it to the housing (you don't have to take the intake apart). look into it, there are two wires, one mounted low and in front, the other mounted high and in the back. the back one tends to get really dirty cause thats the one in stagnation. use a cotton swab and some rubbing alcohol to clean them both. it really smooths the idle if its dirty.
Those who control the present control the past, those who control the past, control the future. - George Orwell, 1984.
bwojdyla is offline
