Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - ZETEC Engine stumble - SOLVED
Old 12-21-2004, 02:20 PM   #45
bwojdyla
bwojdyla's Avatar
Fan#: 3589
What I Drive: Red 2000 ZX3
Points 23,336, Level 93
Points: 23,336, Level: 93 Points: 23,336, Level: 93 Points: 23,336, Level: 93
Level Up 99% Completed
Level up: 99% Level up: 99% Level up: 99%
FF Reputation: 1 bwojdyla Good Standing Member
nope. I was going to take a shot, but it would have been 100% pulled out of my rear end bullshit.
I can tell you some things to do though. First is to reset. Unplug the battery for an hour or so. This will clear the fuel trims stored in the ECU. Your programming will be reset to factory default and the computer will relearn the appropriate fuel curves. try cleaning out the upper intake (cleaning the MAF, filter, check the PCV valve itself). It's probably not any of the servo's like EGR or IAC since those would throw a quick CEL. check your spark plugs for fouling, check to make sure your spark plug wires are in good shape and the ends make strong contact on the coil and the plug, check all the vacuum hoses, not just the one that was bad in this case. that's about all I can think of that would amount to rough running as an easy fix.
Those who control the present control the past, those who control the past, control the future. - George Orwell, 1984.
bwojdyla is offline
