Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Traction control on a car W/O it?
Old 11-05-2011, 04:12 PM   #2
Elizabeth
Elizabeth's Avatar
Fan#: 89280
Points 19,323, Level 87
Points: 19,323, Level: 87 Points: 19,323, Level: 87 Points: 19,323, Level: 87
Level Up 95% Completed
Level up: 95% Level up: 95% Level up: 95%
Forum Activity 17%
Activity: 17% Activity: 17% Activity: 17%
FF Reputation: 24 Elizabeth Great Standing Member
A larger cam the throttle cable winds around at the Throttle body would give you what you want.
By making it bigger around, foot movement on pedal will reduce response, and the total pedal movement to floor will not result in WOT.
(If you made up a new cam you should allow the wire to start nearer. so the cable does not have to be changed in length to fit)
Elizabeth is offline
