Old 11-05-2011, 12:22 AM   #80
Kabigon
Fan#: 88299
What I Drive: 2012 sterling gray Titanium
Points 5,736, Level 48
Points: 5,736, Level: 48 Points: 5,736, Level: 48 Points: 5,736, Level: 48
Level Up 93% Completed
Level up: 93% Level up: 93% Level up: 93%
Forum Activity 5%
FF Reputation: 11 Kabigon Great Standing Member
Originally Posted by DentonFocus View Post
Had my focus PCM and TCM reflashed under the TSB 11-10-2 this past tuesday (11/1/11). after some initial problem w/ a clueless service advisor, the second (very good) advisor went thru the trouble of looking up the TSB, talked w/ me about the symptoms, and scheduled an appointment. Dealer even provided a free loaner car for me.
the reflash was totally worth it - driveability is much better. before the reflash, the trans hesitated to downshift when i applied partial throttle, especially noticeable when coming out of a turn. there was a very small throttle window in which the car would accelerate away at a good speed - not grandma slow and not teenager fast. accelerating from stop was the same and at highway speeds, you literally had to floor the pedal to get a down shift/jerk/acceleration.
After the reflash, shiftpoints were generally higher - around 2750 -3500 rpm. much less hesitation accelerating from stop, coming out of corners, and highway speeds. reflash also cured the rpm surge when coming to a stop. still wish they offered the 5sp manual, but this rework makes the car much more enjoyable. i do not know what the affects on gas milage will be, but TSB was not supposed to lower milage. i would gladly trade a little mgp for driveability. btw, getting 33.0 mpg to date w/ the handling package (tracked mileage on xlsx).
With the new programming, it is smoother and smarter.
It took a while but IMO they nailed it.
Kabigon is offline
