Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - What happens if you have no TPMS?
Old 11-01-2011, 12:17 PM   #8
PratoN
PratoN's Avatar
Fan#: 88058
What I Drive: 2012 Kona Blue Ti Hatchback, DCT
Points 4,677, Level 43
Points: 4,677, Level: 43 Points: 4,677, Level: 43 Points: 4,677, Level: 43
Level Up 64% Completed
FF Reputation: 19 PratoN Great Standing Member
Originally Posted by e350 coupe View Post
Every time you start the car the center display will display a fault message with your TPMS sensors, followed by buzzing and pinging sounds....There will be an additional flat tire indicator in the speedo gauge flashing on and off for a couple of minutes then it will turn solid... And finally there will be an error message between the fuel gauge and temp. gauge.
This will go on and on every time you restart the car.
Would you consider this unbearable? I'm debating whether or not I can justify spending the extra $200 on the sensors. It might be worth it and it saves me from having to get them mounted later.
Your thoughts?
PratoN is offline
