Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - How to: Paint Front Calipers
Old 10-28-2011, 12:05 PM   #11
bbcobra
bbcobra's Avatar
Fan#: 88400
What I Drive: 2003 SVT Competition Orange EAP ZX3
Points 580, Level 11
Points: 580, Level: 11 Points: 580, Level: 11 Points: 580, Level: 11
Level Up 60% Completed
FF Reputation: 2 bbcobra Good Standing Member
I used the G2 paint kit to do my calipers on the cobra.
http://www.stage3motorsports.com/pro...mpaign=G2BCPBL
It is an epoxy based paint and very tough. It would be much better than regular paint but not as tough as powdercoating. Powdercoat is cooked at 400 degrees for about 30 minutes so you cant have any rubber seals left in there.
I plan to paint the ones on the focus when ever I redo the brakes.
Oh, If you paint the rotors it will make a huge difference also. I painted mine while still on the car. Just use painters tape to mask the pad surfaces and bolts. remove the calipers. Dont forget to also get the outside of the rotor and fins. Mine were like this for about 3 years and still looked pretty good when I replace them last year with new rotors.
03 SVT Focus, Comp Orange, EAP, Eibach sway bars, H&R Race Springs, Koni Sports, steeda shifter, Massive camber arms, toe links, engine mount bushings, sway bar end links.
other car: 2004 SVT Cobra Coupe, Screaming Yellow, 2.76/2lb lower...
bbcobra is offline
