Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - throttle body problems
Old 10-25-2011, 06:01 PM   #2
st12131
Focal Distortion
st12131's Avatar
Fan#: 74797
What I Drive: 2007, Huyndai, Santa Fe, GLS
Points 3,537, Level 37
Points: 3,537, Level: 37 Points: 3,537, Level: 37 Points: 3,537, Level: 37
Level Up 25% Completed
FF Reputation: 10 st12131 Great Standing Member
It is the electronic throttle control system. Most likely it is the throttle position sensor in the TB, which can not be replaced. You have to install a complete new/used TB. It should only be a $200 part and you can install it your self. I had the same problem on my 2010, but was fixed under warranty
Your drivetrain should be under a 5/60,000. If you still have it, it will be covered.
Posted via FF Mobile
st12131 is offline
