Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - So I blew up my Duratec 2.0L time for new engine.
Old 10-20-2011, 09:04 AM   #29
megax36
Fan#: 41533
What I Drive: 09' Black SE
Points 1,178, Level 18
Points: 1,178, Level: 18 Points: 1,178, Level: 18 Points: 1,178, Level: 18
Level Up 78% Completed
FF Reputation: 4 megax36 Good Standing Member
Yes it will fit; the only difference between the two is that the 2.3 has a taller short block to equate for its longer stroke. Also the fuel rail will not be a problem, just use everything from your current engine minus the stuff I mentioned earlier.
If your exhaust manifold is cracked, it's best to just get another one or either get a patch welded on your current one. The exhaust manifold from the 2003 is the PZEV version which is more restrictive, so you wouldn't want that. Going aftermarket is also a choice, but then we're talking more money.
megax36 is offline
