Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - So I blew up my Duratec 2.0L time for new engine.
Old 10-18-2011, 01:55 PM   #10
megax36
Fan#: 41533
What I Drive: 09' Black SE
Points 1,178, Level 18
Points: 1,178, Level: 18 Points: 1,178, Level: 18 Points: 1,178, Level: 18
Level Up 78% Completed
FF Reputation: 4 megax36 Good Standing Member
If you read what I wrote above you will realize that unless you are going to use the IM from the 2.3 engine, you will not need anything from the 2.3 other than the engine itself.
The 2.3 IM has a set of tumble flaps that the 2.0 IM does not have. Thus if you plan to use it you will need the harness and the ECU from the 2.3 in order to utilize it. That is why I recommended that you stick with your 2.0 IM and keep it simple.
megax36 is offline
