Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - any modifacations for the 2012 focus SEL
Old 10-17-2011, 09:16 AM   #26
SPRAYPAINT
SPRAYPAINT's Avatar
Fan#: 89747
What I Drive: 2014 Sterling Grey Focus SE Sedan
Points 2,741, Level 31
Points: 2,741, Level: 31 Points: 2,741, Level: 31 Points: 2,741, Level: 31
Level Up 94% Completed
FF Reputation: 2 SPRAYPAINT Good Standing Member
Originally Posted by DirtKonaZX3 View Post
Well, since Ford decided to stop making the rear caliper mounting bracket for the SVT it means no more rear drum to disc conversions. Nobody has any Ford SVT kits either. So I was thinking Mazda 3 rear disc conversion instead.
Sorry about taking so long to get back on this matter. The Mazda rear disc brake swap should work. There are a couple differances. The Mazda is a 5X114.3 bolt pattern and the brake hydraulic system is different. With your time and $$$ I am sure it can be done. The front steering knuckles should swap right over. Then you would open a much larger wheel option as well.
SPRAYPAINT is offline
