Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Deleting the tumble flaps
Old 10-15-2011, 11:50 AM   #35
S0C0nFused
S0C0nFused's Avatar
Fan#: 39405
What I Drive: 2007 TorD-Red ZX5 SES
Points 12,348, Level 72
Points: 12,348, Level: 72 Points: 12,348, Level: 72 Points: 12,348, Level: 72
Level Up 75% Completed
FF Reputation: 77 S0C0nFused Excellent Standing Member
Originally Posted by BowerR64 View Post
You know i haven't done allot plugging holes on plastic, these intakes are more of a composite then a plastic its got fibers in it and seems more brittle it acts allot like cast metal or something.
I hear ya! but what you want is mechanical grip. Rubber is not 'mechanical' like a sleeve or epoxy. Rubber has poor 'memory' and will let go. If the flanges are only 1/4" deep, then use a blind rivet or blind threaded insert (absolutely no chance of coming loose). But maybe that is to much hassle (not much room in there granted). Then may I suggest simple hard wood dowel. Rough up the plastic, then insert a dowel soaked in glue (note: at this time I don't which glue). A hard wood dowel will swell as the glue impregnates its fibers, making a very tight plug. Note: You want a glue that is fairly 'runny', and has a slow set-up time. But you will also want a glue that is not affected by gas when DRY, and has a good temp range! There are several that meet most of these criteria, fewer have the necessary temp range.
Paint >> I have found any 'metalic' paint is runny, and splotchy. I also don't know why. But they still look good!
Steeda SRI w/CAI intake. Trubendz SS 2.5" . FR Susp/Struts. Tune by Tom (FocusPower). Rota Grids. SAP rear spoiler. Custom front air dam, rocker panel bits and Rear valance.
Last of the Hatches #28
S0C0nFused is offline
