Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Deleting the tumble flaps
Old 10-13-2011, 08:23 AM   #26
megax36
Fan#: 41533
What I Drive: 09' Black SE
Points 1,178, Level 18
Points: 1,178, Level: 18 Points: 1,178, Level: 18 Points: 1,178, Level: 18
Level Up 78% Completed
FF Reputation: 4 megax36 Good Standing Member
Jgrove is correct, if you vent the pcv without also venting the valve cover, the system will reverse flow. You must disconnect both from the intake, otherwise it's quite pointless. It is also recommended that you drill out the spring in the pcv valve, so more of the fumes will vent through that instead of your valve cover.
megax36 is offline
