Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - How to: USB2 add media (2012 focus)
Old 10-08-2011, 09:07 PM   #16
Jgetz524
Fan#: 90377
What I Drive: 2012 black SEL sedan
Points 4, Level 1
Points: 4, Level: 1 Points: 4, Level: 1 Points: 4, Level: 1
Level Up 7% Completed
FF Reputation: 1 Jgetz524 Good Standing Member
Originally Posted by Dethpickle View Post
Forgive me... That doesn't help at all.
I've got a small screwdriver that fits in. I've done everything with it that I think I could do with a paper clip. I've pressed pretty hard in the center and tried to pull it out. I've tried screwing it several directions. Pressing it different directions... no dice.
What am I trying to release? Should I be pushing it one way or another?
None of that helped me either. I ended up pulling on the panel hard enough that that plug released. After having the plug out, I see nothing that could result from using that center hole.
Since the plug is recessed and has a cover over it, I used a sheet metal screw with the proper diameter in place of the plastic plug. If I ever want to take the panel off agian, no more drama.
Jgetz524 is offline
