Old 10-07-2011, 01:28 PM   #191
PratoN
PratoN's Avatar
Fan#: 88058
What I Drive: 2012 Kona Blue Ti Hatchback, DCT
Points 4,586, Level 43
Points: 4,586, Level: 43 Points: 4,586, Level: 43 Points: 4,586, Level: 43
Level Up 18% Completed
FF Reputation: 19 PratoN Great Standing Member
I (and many others) have been posting transmission issues in the non-performance section of 2012 Focus (whoops!)
Here's an update on that pulled TSB:
Originally Posted by Kabigon View Post
P068A - Indicates the non volatile random access memory (NVRAM) write did not complete successfully after the ignition key was turned off, prior to PCM shutdown. This DTC sets when the PCM power relay is de-energized too early.
P2610 - Indicates an error in the internal PCM engine off timer processor. The test fails when the difference between the engine off time and the central processing unit (CPU) time exceeds a calibrated limit for a calibrated amount of time.
For these DTCs, the technical details probably aren't important because there is a TSB that covers these issues:
TSB 11-10-2
Publication Date: October 2, 2011
Some 2012 Focus vehicles built on or before 8/12/2011 may exhibit the following engine drivability and/or automatic transmission concerns; RPM flare on deceleration coming to a stop, rough idle on deceleration coming to a stop, intermittent engine idle fluctuations at a stop, intermittent vehicle speed control inoperative, intermittent harsh engagement/shift, engine no-start with engine coolant temperature (ECT) open circuit faults and intermittent no-crank/no-start condition after performing normal Powertrain Control/Emissions Diagnosis (PC/ED) pinpoint test (PPT) diagnostic procedures. The vehicle may also exhibit diagnostic trouble codes (DTC) U0422, P00D2, P068A, P0850, P2610, P2832, P286F or P2877. The vehicle may also exhibit intermittent false initialization to 21 C (70 F) on the instrument cluster's ambient temperature display upon engine start up.
The fix is a simple reprogramming of the PCM and TCM.
Not that it seems to matter, because my dealer told me "That's how these transmissions work."
That's how they work - but they've changed something on models after 8/12/2011 and won't tell us what or why? I guess I didn't know dual-clutch transmissions were supposed to make crunching noises when shifting gears... I'm just trying to save Ford (and myself) a headache and $$ when my transmission fails in 3 years due to bad programming and the warranty will have to pay for it.
Btw, I'm at 7,500 miles and will be checking this issue at a different dealer tomorrow.
PratoN is online now
