Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - DSP build - opinions and suggestions welcome
Old 10-06-2011, 06:16 PM   #22
gmracing
Fan#: 70744
What I Drive: 2005 white SVT
FF Reputation: 1 gmracing Good Standing Member
Originally Posted by BLK2k3GTS View Post
So after having a talk with my brother Zab, we have finally decided what we want to do in the near future. I''ve been racing against 2 SVT foci in ST (Zab's and Tukani's (Ray)) in my Eclipse.. and so far its been fun but we feel like its in DSP where its at!
We all know that at national level, BMWs own DSP..but before I get down to the future mod list I'd like to ask if there's anyone who has actually fully built a true DSP Focus to the point where you could actually said "I've done everything I could..but Im still loosig!" kind of thing.. I believe if we max out the Street Prepared rule book we might actually have a chance at 2013-2014 Nationals. (hoping the world doesnt end in 2012.. LoL)
Suspension:Zab's SVT has all stock suspension, except for Moog endlinks up front and Energy Suspension on the rear..so:
Koni Yellows with H&R Race springs
H&R rear sway bar
Stock front sway bar with new bushings
CFM tubular control arms
Rear Stress bar
Front strut tower brace
Polyurethane bushings where needed
Under the hood:
Zab's SVT is already equiped with:
AEM cold air intake
Steeda motor mounts
CFM dogbone mount with Race bushings
Taylor wires
Copper plugs
130amp alternator from CFM
The entire A/C system is there, but its running on a shorter belt skipping the compressor.
It used to have Tom's tune, but somehow messed it up and its back to stock. But we are already working on getting it re-tuned.
Plan on getting:
67mm throttle body
3" header back exhaust with ORP
lightweight battery
Maybe - TopSpeed's intake manifold
We are planning on keeping the engine internals as they are....for now..
Brakes:
PowerSlot cryo treated rotors
Hawk pads
Stainless steel brake lines
DOT4 brake fluid
New seals for calipers
Transmision:Clutchmasters Lightweight flywheel + clutch combo
MTL RedLine transmision fluid
LSD *need advice!
Weight Reduction:
Carbon fiber hood
carbon fiber hatch (maybe)
Racing seats (not sure which brand/style yet)
Back seat delete
Wheels and Tires:
275/35-15 Hoosies on either 9" or 10" wide wheels for divisionals and nationals --not sure which wheels to get *need advice!
225/40-16 for regionals
Im sure I missed a few things.. but we would like to hear from yall. Suggestions and opinions are very much welcome
There are a couple of things
1. Have you heard of update & backdating, it means you can put the little brake from the early Focus's and then put the 15" wheels on. For autocross brake are not a big deal.
2. Be careful what you do to the motor, The engines block, head, trans (but you can update & backdate this part for the right 2nd gear ratio) Diff gear have to be stock on the focus but you have 9 to chose from.
The rules can work for you or against you, work on 1 thing at a time and double check the rule book so you don't waste money.
Ben
gmracing is offline
