Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - About to swap SPI to Zetec
Old 10-02-2011, 12:27 AM   #7
KUEHN8898's Avatar
Fan#: 68858
What I Drive: 05 Dark Grey ZX4
FF Reputation: 1 KUEHN8898 Good Standing Member
i used zetec ac compressor and lines but flipping it 180 degrees may work.
starters are the same
some ps pumps are same mine wasnt you need the whole harness from fuel pump forward, runs down passenger side to fender well into engine bay. halfway there it goes under passenger seat to shifter.
also need zetec trany harness that goes to o2 sensors an trans.
exhaust manifold and flex pipe
air intake tube but boxes are same
passenger motor mount and the black stand it mount to
someone told me the fuel line that goes from fire wall to engine is needed i got one but they looked the same
high pressure power steering line that runs across front of engine
heater core hoses (i just pluged the T and extended my hose with some heater hose from oriellys
youll need the throttle cable and cruise cable their both diff, cruise may work with mod to braket but throttle wont. its super easy to change it
grab extra bell housing bolts from donor car zetec uses more than spi.
Also some people say trans wont work but i researched them and part numbers are same so i took the risk and tried mine it works and shifts perfect so you shouldnt have any problems using yours just make sure you for sure change that trans harness the spi and zetec are 2 pins different in wiring so it could have all the wires in diff spots that harness also needs to be from about same year car cuz newer ones use diff power steering pumps and have diff connectors and more wires.
Thats all i can think of right now any other questions shoot me a message
i tried to pm you but mine wont work
88 Mustang GT 5.0
84 Mustang GT Ttop- for sale
91 Mustang LX 5.0
05 Focus ZX4 Duratec
06 Ford Fivehundred limited
KUEHN8898 is offline
