Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - SaleenT's Duratec 2.0L Build
Old 10-01-2011, 05:43 PM   #52
Djzx3
WRX/Focus:)
Djzx3's Avatar
Fan#: 76864
What I Drive: 04 WRB WRX / 00 se zxw
Points 14,826, Level 78
Points: 14,826, Level: 78 Points: 14,826, Level: 78 Points: 14,826, Level: 78
Level Up 94% Completed
FF Reputation: 33 Djzx3 Great Standing Member
Buy-Sell-Trade Rating: (6)
Originally Posted by SaleenT121 View Post
While the car is apart i had decided to upgrade the clutch from my previous spec stage 1 to a spec 2+ 6 puck. I only had 1000 miles on that thing but spec re searfaced my flywheel and upgraded it for cheap. The factory 2.0 had a dual mass so i decided to use an Exedy OEM replacement single mass that is a good bit lighter that that hunk of dual mass garbage. It added up to be about 9lbs lighter than factory....
Note : The spec clutches you buy will not fit the Exedy 2.3L flywheel.
They will fit the factory(flywheel) only, the clutch seems to be too big!
Spec is trying to fix this issue, since you cant machine our flywheels.
They will match your clutch with whatever flywheel choose to you have.
Very nice parts man, I myself am dealing with the flywheel in my 03 2.3l MTX75.
Did you originally replace the a dual mass flywheel with a single piece flywheel?
And if so, could you recommend some good conversion kits for my 03 2.3l? I have the DM flywheel, and I am looking to replace it with a single piece, no serous HP or anything, just a conversion kit. Know any good one's for less then $527?
I found this one> http://www.phoenixfriction.com/p-237...-23l-8-78.aspx < but it seems a little high to me on pricing?
2000 SE wagon 2.0l Zetec.
HN #17
D23 crew-#1
Djzx3 is offline
