Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - ZX5 engine stumble when stopped, help!
Old 09-30-2011, 11:47 AM   #6
pumafeet10
Fan#: 37417
What I Drive: 2003 Yellow ZX5
Points 766, Level 14
Points: 766, Level: 14 Points: 766, Level: 14 Points: 766, Level: 14
Level Up 66% Completed
FF Reputation: 1 pumafeet10 Good Standing Member
Everything has been checked over, and the battery was disconnected form the entire install time, so plenty of time to reset the ecu.
I checked for leaks using some soapy water to watch for air bubbles but nothing,
I'm not just randomly searching, as there is an abundance of sensors that are in the area and could have been disrupted during install, that were fine before, like the dpfe sensor.
If it was the Maf it would be causing a problem all the time, no?
It only happens when we are stopped, which is why I was leading to the dpfe as it is vacuum operated with the erg, possibly not getting enough flow at idle
pumafeet10 is offline
