Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2012 Focus - Aftermarket Stereo possibilities.
Old 09-28-2011, 09:26 AM   #7
herbz
Fan#: 84909
What I Drive: 2012 SE Hatch 5MT Sterling Grey
Points 8,470, Level 62
Points: 8,470, Level: 62 Points: 8,470, Level: 62 Points: 8,470, Level: 62
Level Up 7% Completed
FF Reputation: 1 herbz Good Standing Member
Originally Posted by mikeJones View Post
Why not just swap speakers and have an amp and clean sweep installed?
This is definetely the easier method, however, in most cases an aftermarket headunit will always sound better than a stock headunit + LOC. In addition, aftermarket headunits can be purchased with features like Nav, bluetooth, USB integration. The base model headunit does not have any of these.
As far as using the factory dash kit from the Sony system to use with an aftermarket headunit, I doubt it would work as standardized mounting brackets are probably not present in the stock dash kit. It would most likely have to be modded to be able to hold an aftermarket radio.
herbz is offline
