Old 09-23-2011, 10:16 AM   #1123
Dedbent
Fan#: 87677
What I Drive: 2011 Ebony SE
Points 435, Level 8
Points: 435, Level: 8 Points: 435, Level: 8 Points: 435, Level: 8
Level Up 70% Completed
FF Reputation: 1 Dedbent Good Standing Member
Originally Posted by crice8 View Post
they should not have came off. i havent had any problems with mine and i drive right after an i even go through the big drive through car was that uses the big things that slap your car and everything. are you sure you cleaned the surface with alcohol? did you allow that to dry for 10 mins? something had to be missed with the install
No, I used alcohol to clean the surface and did not drive for a few hours. I was going 85-90mph down the highway though. When I got to work I noticed some of the edges coming off. Maybe the adhesive was bad/old? It is always tricky gluing something to a curved surface.
Dedbent is offline
