Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - changing rear brake shoes on 03 Focus
Old 09-22-2011, 06:39 PM   #4
ABFORDGUY
Fan#: 89202
What I Drive: '90 Miata wife has the 2012 Ti
FF Reputation: 2 ABFORDGUY Good Standing Member
Hope this helps, sorry it won't let me paste in the pictures. I am not a tech, but this is from the workshop manual
Removal
All vehicles
Remove the parking brake control boot.
Detach the boot clip.
Remove the boot.
NOTE: Make sure the rear brakes are at a cool temperature.
Release the parking brake control to its lowest position.
Loosen the parking brake cable adjustment nut until there is no tension in the cable.
Remove the retaining clip.
Loosen the adjustment nut.
Remove the wheels and tires.
Vehicles with anti-lock brakes
Detach the wheel speed sensor.
All vehicles
CAUTION: Do not remove the brake drum by means of the hub retaining nut.
Remove the brake drum and hub assembly.
Remove the hold down springs.
Remove the pins.
CAUTION: Do not damage the wheel cylinder boots.
Disconnect the shoes from the wheel cylinder.
Detach the shoes from the anchor block.
Hold the wheel cylinder pistons in place with a rubber band.
Disconnect the parking brake cable.
Push the lever inwards.
Disconnect the cable.
Remove the lower return spring.
Remove the upper return spring.
Remove the primary shoe from the strut and brake shoe adjuster.
Pull the shoe outwards.
Disconnect the strut.
Release the strut.
CAUTION: The strut support spring is under tension.
Detach the secondary shoe from the support.
Move the strut downwards.
Detach the parking brake return spring.
Installation
All Vehicles
CAUTION: Make sure that all mating surfaces are clean of foreign material and debris.
Clean, check and apply silicon dielectric compound grease to the backing plate contact points.
Install the strut support to the secondary shoe.
Install the parking brake return spring.
Move the strut upwards.
Install the primary shoe to the strut and brake shoe adjuster.
Install the strut.
Push the shoe inwards.
Rotate the adjuster fully clockwise.
Install the upper return spring.
Install the lower return spring.
Install the parking brake cable.
Connect the cable.
Remove the rubber band holding the wheel cylinder pistons in place.
Connect the shoes to the wheel cylinder.
Connect the shoes to the anchor block.
Install the hold down springs.
Install the brake drum and hub assembly.
Install the wheel speed sensor.
All Vehicles
Install the wheels and tires. For additional information, refer to Section 204-04.
NOTE: The internal auto adjuster must be set and the brake shoes centralized to the brake drum.
Rotate the rear wheels and apply the brake pedal four times.
Carry out parking brake cable adjustment.
ABFORDGUY is offline
