Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Not going into gear all the way??
Old 09-07-2011, 06:06 PM   #6
Mike_Mac
Mike_Mac's Avatar
Fan#: 61110
What I Drive: 13&14 SE hatch
Points 2,703, Level 31
Points: 2,703, Level: 31 Points: 2,703, Level: 31 Points: 2,703, Level: 31
Level Up 69% Completed
Level up: 69% Level up: 69% Level up: 69%
FF Reputation: 12 Mike_Mac Great Standing Member
Buy-Sell-Trade Rating: (8)
it will guarantee that it will go into 1st and you can see if it still grinds 1st. if not you will need to play with it till it goes into all the gears. if it grinds first after doing that then you got more issues.
or get the plate then for uses to center the shifter. (or a 2nd person that can hold it dead center.)
i believe its cable related because your having issues with 1,3,5 so my bet is its not pulling the shift tower far enough. and adjusting it like i said chances are your issue will then be hard getting into 2,4,R. then you need to find a happy middle point, but bad shifter bushings will make that almost impossible
Mike_Mac is offline
