Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2012 Focus Custom Ram Air How-To
Old 09-06-2011, 04:29 AM   #62
newmission
newmission's Avatar
Fan#: 84688
What I Drive: YB-MK3-MTX-SE-OG Sport-HB
FF Reputation: 5 newmission Good Standing Member
Originally Posted by DaeGoesFast View Post
Looking at the pictures, I can't tell if the mod introduces the air before or after the MAF sensor. If before, I'd say your fine since the computer should still know exactly how much air is going to the engine. However, if the mod introduces air after the MAF sensor, then your air flow past the sensor should decrease, and may cause the computer to spray less fuel into each cylinder charge, which would explain the significant MPG increase. This may not be a big deal (my car has had the CEL on for years due to a lean fuel code), but I've heard that lean fuel mixtures can be harmful at higher RPMs, due to the hotter combustion of a lean mixture.
The factory air box is before the MAF. The pictures show a 3 inch hole being drilled into the factory air box. You're good.
Hatch Nation #110
Debadge-and Drive Naked
Home of the Free Blacked Out Grille Mod, and Griffin Ram Air Mod.
Get you some!
newmission is offline
