Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Speedometer Lighting
Old 08-30-2011, 09:32 PM   #12
Elizabeth
Elizabeth's Avatar
Fan#: 89280
Points 19,584, Level 88
Points: 19,584, Level: 88 Points: 19,584, Level: 88 Points: 19,584, Level: 88
Level Up 47% Completed
Level up: 47% Level up: 47% Level up: 47%
Forum Activity 24%
Activity: 24% Activity: 24% Activity: 24%
FF Reputation: 24 Elizabeth Great Standing Member
Originally Posted by hotleadsingerguy View Post
With the way you write sentences I'm surprised you can read the numbers on the gauges at all.
They're fine. I'm 6'3" and have *no* trouble at all seeing the gauges and reading them all easily. For the people having problems...you realize the steering wheel can be moved, right? There's no reason you should be having trouble reading the gauges at all.
I LOVE the steering wheel. Small cool as can be. Tons of adjustment. Nice controls on wheel.
Have to say this Focus steering wheel is about as good as it gets.
The only thiing i think might be not so great is the switches on the lower sides seem a bit cheap. IF they hold up to use, then it is great!!!
(The trim glare is just finding the right stuff to dull it. Even if the aluminum were dull, that would be enough. As i mentioned ,I plan on painting the trim with acrylic paint, some clear 'duller' (from artist acrylic will do the job.)
Elizabeth is offline
