Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - HOW-TO: Swap in Tilt Steering Column/Replace Clockspring.
Old 08-28-2011, 07:14 PM   #33
lumr002
Fan#: 89314
What I Drive: 2001 Red Ford Focus
Points 5, Level 1
Points: 5, Level: 1 Points: 5, Level: 1 Points: 5, Level: 1
Level Up 9% Completed
FF Reputation: 1 lumr002 Good Standing Member
Great Post
2001 Ford Focus SE Station Wagon. Hey, I used your instructions to replace my clockspring because my turn signals would not cancel. Sure enough, the black plastic tab on the clockspring that cancels the turn signals was broken off. Using your instructions, it took me only 45 minutes and that was because it was on a hot day and I took some rest breaks. Also used the Ford Technical Service Bulletin (TSB) #04-5-5 which indicates that a 9mm spacer has to be installed to prevent the problem from reoccurring. Bought the Clockspring from O'Reilleys and the spacer from the Ford dealership. Spacer costs $20 at Ford. Great instructions and great pictures....THANKS!!!
lumr002 is offline
