Old 08-24-2011, 07:59 PM   #149
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 32,482, Level 100
Points: 32,482, Level: 100 Points: 32,482, Level: 100 Points: 32,482, Level: 100
Forum Activity 57%
Activity: 57% Activity: 57% Activity: 57%
Originally Posted by sirhawkeye View Post
Is it possible that oil is being pushed into areas in the engine and just staying there during the so-called "break-in" period. I'm going to have the oil changed here in the next week with full synthetic, and then I guess I'll watch then.
Just add a little oil to it if it bothers you, and use Ford's blend that's readily available. I'm sure it won't hurt anything.
About the first sentence- no. It was probably simply not filled all the way from the factory. You might want to stick your head under there and see if there's oil on the filter. That would be about the only place that I'd figure it would leak from. If there is seepage there, then you should be able to get a warranty oil change from your dealer. They might just tighten it down and add some oil- either one would be ok.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
