Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Rough Idle and Manual Transmission Noise
Old 08-06-2011, 01:02 PM   #5
Eurofordfan
Fan#: 87186
What I Drive: 1985 Moto Guzzi T5 850 NT
FF Reputation: 1 Eurofordfan Good Standing Member
That rattle, in neutral, with the clutch pedal out, is called roll-over rattle. It will only happen when the transaxle fluid is hot; it is totally harmless. By comparison, you should hear how rattly a diesel tractor is, with the thirteen or eighteen speed Eaton transmission!
If, by comparison, it makes noise when the clutch pedal is pushed-in, then it may very well be the throwout bearing. That is a cause for concern, 'cause it's so much of a "beach" to get to!
Don't worry about roll-over rattle. And notably do not change transfluid to attempt to quiet it down; trans fluid viscosity is very carefully chosen by the designers, to ensure that lubrication of the needle roller bearings (in the case of the MTX75 transaxle) get lubricated properly! Also, the fluid properties figure big-time into the behavior of the synchronizers.
Eurofordfan is offline
