Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - From stock 2001 S2 to new 450hp+
Old 08-05-2011, 05:16 PM   #319
iroc34
iroc34's Avatar
Fan#: 69289
What I Drive: 02 ZX 3 TURBO , MURDERED.
Points 5,612, Level 48
Points: 5,612, Level: 48 Points: 5,612, Level: 48 Points: 5,612, Level: 48
Level Up 31% Completed
FF Reputation: 18 iroc34 Great Standing Member
Buy-Sell-Trade Rating: (13)
Originally Posted by Mother Focus View Post
Couple of things,
-new radiator (was blocked, potentially the culprit of the head gasket issue), new rack & pinion, rear main seal and new clevite main and rod bearings ( the material left on the head marked the cam and the bearings in the fourth cylinder), new metal valve cover and throttle cable, arp flywheel bolts and manifold studs.
-ordered Comp cams 273, turns out the cam marked was OEM, apparently the first machine shop, same one that left material in the oil passages, broke the FR 3 and replaced them with OEM's.
-Sold my turbo, thanks Bmylez, and waiting on a new one, hope is soon.
You have got to be kidding ? They swapped out your cams. WTF. I would of lost my mind. What did they tell you ? They should cover the cost of the rebuild. That's terrible. I hope you have better luck now. Who is doing the rebuild now ?
iroc34 is offline
