Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 588whp 500tq just got off the dyno :)
Old 08-02-2011, 09:13 PM   #73
iceberg65
Fan#: 64382
What I Drive: 00 laser red cougar
Points 299, Level 5
Points: 299, Level: 5 Points: 299, Level: 5 Points: 299, Level: 5
Level Up 98% Completed
FF Reputation: 2 iceberg65 Good Standing Member
Originally Posted by inkedfireman View Post
I know that feeling! After I blew my first motor, I got a used long block and put it in. Tried to start it, and no joy. Turns out I had no spark because the new long block was out of an auto car, and the crank position sensor bracket (that bolts on behind the flywheel) is different from a manual.
Like you said, it sucks to have to drop the tranny right after getting everything back together.
Exact same thing happened to me; 99% of 4 cyl cougars are manual so the bit of info didnt exist on my most commonly used forum.
For the shifter base; some contours had a metal base if you have a nearby junkyard to look around. Not 100% on the fitment with the focus; as long as its a cable shift (some were rod shift) I would think it would work. Probably easier to find then an svt unit.
iceberg65 is offline
