Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Remote start and push button start
Old 07-22-2011, 11:13 PM   #14
Tony407
Tony407's Avatar
Fan#: 85289
What I Drive: 2012 Sterling Gray Hatch Titanium
Points 11,374, Level 70
Points: 11,374, Level: 70 Points: 11,374, Level: 70 Points: 11,374, Level: 70
Level Up 31% Completed
FF Reputation: 4 Tony407 Good Standing Member
Originally Posted by vinnfizz View Post
I ordered the remote start system on my 2012 SEL 303a Kona Blue Metallic expecting it to come factory installed but my salesman and I both were surprised when it turned out to be a "Dealer Installed" option and adds a separate key fob with one button on it. My dealers install guy had to wait on an installation wiring harness to come in specific to the 2012 model so it was a week after delivery I had to take it back to the dealer for installation. The system works ok but then I found the next day that after a remote start as you approach the car to unlock the doors the engine shuts down. That made no sense at all! I took it back to the dealer and they disabled the door ajar function on the remote start interface and now I can unlock the doors with out a shut down. If you step on the brake getting in before the key is turned to the II position the engine will shut down. The antenna for the system is a 1 1/4 X 1 in. x 1/4 in. block with 2 1/2 in antenna extending from two sides. It was installed to the interior windshield to the right of the rearview mirror, out of sight to the driver but I am sure it will be an obstruction to window cleaning.
Would you mind giving us the name of the dealer that did this? Mine can't seem to figure out how to make it so the engine doesn't shut off when you open the door. If they had someone to call that's done it already, it might make a difference. Thanks!
Tony
Tony407 is offline
