Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Wrench dash light
Old 07-18-2011, 02:06 PM   #50
Gabe2010SE
Gabe2010SE's Avatar
Fan#: 70327
What I Drive: '13 Mustang 5.0L 6spd, '10 Focus SE
Points 3,285, Level 35
Points: 3,285, Level: 35 Points: 3,285, Level: 35 Points: 3,285, Level: 35
Level Up 57% Completed
Level up: 57% Level up: 57% Level up: 57%
FF Reputation: 2 Gabe2010SE Good Standing Member
Originally Posted by xtcj98 View Post
I have a 2011 SE with 3980 miles. This past tuesday the wrench light came on at two different times. Both times the vehicle would resart after stopping and letting sit for 10 seconds. It has no CEL on. The second time it happened was in the middle of a very busy intersection. I had it towed to the dealership it came from. The say the can not find any codes or any problems with it. They have provided me with a new Chevy HHR to drive in the meantime. I am still using the Chevy. My last new car was in 1973, this is not making me feel my new purchase was a good idea.
I have not found any TSB's on my own and the dealer finds nothing wrong with the car.
Any suggestions?
How about this one, posted by me on same "page 4" as your post ?
Originally Posted by Gabe2010SE View Post
TSB 10-21-06 ... "DTC P2111 OR P2112, OR LOWER THAN DESIRED ENGINE IDLE SPEED, ENGINE IDLE SPEED FLUCTUATES WITH OR WITHOUT DTCS "
FORD: 2010-2011 Focus, Fusion, Taurus
2010 E-150, E-250, Edge, F-150
2010-2011 Flex
LINCOLN: 2010-2011 MKS, MKZ
2010 MKX
2010-2011 MKT
ISSUE:
Some 2010 Edge, MKX, F-150, E-Series, 2010-2011 Flex, MKT, Focus, Taurus, MKS, Fusion and MKZ vehicles with any of the following engines: 2.0L, 3.5L (excluding GTDI), 3.7L and 4.6L 2V, may exhibit Diagnostic Trouble Codes (DTCs) P2111, P2112, or the idle speed drops lower than desired and/or fluctuates. The idle speed concern can be intermittent and DTCs P2111, P2112 may or may not be present.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
Determine engine build date. Refer to Workshop Manual (WSM), Section 303-01, Engine Identification for details.
If engine build date is within date range indicated below, proceed to Step 2.
2.0L - 2/11/2010-8/2/2010
3.5L and 3.7L - 3/1/2010-8/3/2010
4.6L 2V - 5/7/2010-8/2/2010
If engine build date is not within range in 1A, do not continue with this article. Refer to Powertrain Control/Emissions Diagnostics (PC/ED) manual for normal diagnostics.
If vehicle exhibits any of the following symptoms, replace the throttle body. Refer to WSM, Section 303-04.
DTC P2111 and/or PP2112
Idle speed lower than desired
Idle speed fluctuates
PART NUMBER PART NAME
7T4Z-9E926-FA Electronic Throttle
8S4Z-9E926-B Electronic Throttle
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
'13 Mustang GT SterlingGray, 6-spd man, Recaros, Track Pack. Ordered 6.6.12, born 7.25.12, mine 8.11.12. 2.3L Whipple & a few other things. 541 RWHP, 478 RWTQ
Gabe2010SE is offline
