Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2012 Ford Focus Scheduled Maintenance
Old 07-16-2011, 10:45 AM   #7
Fan#: 87350
What I Drive: 2012, White, Ford Focus
FF Reputation: 1 immaengineer Good Standing Member
Originally Posted by DrkKnight614 View Post
Posted via FF Mobile Technically I guess. I would still check my oil once in a while and depending on your driving Id probably still change the oil before 10k, especially if you are in a lot of stop and go traffic or running to the store etc a lot. Keep an eye on other fluids too and obviously tires, and clean battery terminals. The air filter is a no change filter, the transmission is dry, so no fluid there. And your belt is actually a chain. So yes technically a lot of the tune up stuff youd normally do pretty much should last a really long time.
Dry in the case of the transmision doesn't mean no fluid, just less than the typical application.
immaengineer is offline
