Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2012 Ford Focus Scheduled Maintenance
Old 07-16-2011, 06:04 AM   #8
cuke2u's Avatar
Fan#: 87358
What I Drive: It's in my sig..
FF Reputation: 2 cuke2u Good Standing Member
Hi, this is our service schedule for the 1.6 ecoboost, I hope this isn't against the forum rules if so mods please delete:
Driving Vehicle into Workshop
Instrument gauges, warning/control lights and
Check operation
Clutch Check operation/adjust, if necessary
Washers, wipers Check operation/adjust, if necessary
Inside Vehicle
Exterior and respective control lights;
instrument cluster illumination
Check operation/condition
Handbrake Check operation/adjust, if necessary
Seat belts, buckles and stalks Check operation/condition
Warning vest Check availability - if applicable
First aid kit Check availability and expiry date - if applicable
Warning triangle Check availability - if applicable
Outside Vehicle
Road (MOT) test Check regarding next road (MOT) test due date - if applicable
Emission test Check regarding next emission test due - if applicable
Under Hood
Wiring, pipes, hoses, oil and fuel feed lines Check for routing, damage, chafing and leaks
Engine, vacuum pump, heater and radiator Check for damage and leaks
Coolant Check anti-freeze concentration: C
Headlamp alignment Check - adjust alignment, if necessary
Brake fluid Check/top up fluid levels as necessary - in case of abnormal fluid loss, a separate order is
required to investigate and rectify
Under Vehicle
Engine undershield Remove/install engine undershield, if fitted (LTS 21 130 4)
Engine Drain oil and renew oil filter
Steering, suspension linkages, ball joints,
sideshaft joints, gaiters
Check for damage, wear, security and rubber deterioration
Engine, transmission Check for damage and leaks
Pipes, hoses, wiring, oil and fuel feed lines,
Underbody Check condition of PVC coating
Tyres Check wear and condition, especially at tyre wall, note tread depth
RF mm, LF mm, LR mm, RR mm
Brake system With wheels on, check brake pads and discs for wear. Check rear brake drums - in case of
abnormal fluid loss, a separate order is required to investigate and rectify. (More often
under severe duty conditions).
Outside Vehicle
Engine Refill engine oil
Tyres Adjust pressure
Instant mobility system Check best before date on tyre sealant - if applicable
Spare wheel Adjust pressure, check wear - condition (note tread depth)
Luggage compartment lamp Check operation - if applicable
Service reminder sticker Affix to driver side B pillar
Interim Service & Convenience Checks
Model Focus 2011
Variant 1.6L ECOBOOST SCTI (01/2011 - )
Interval 1 Years (12500 ml)
Repair/Order No
Reg. No.
Reg. Date
Radio Code
Mileage ml
Outstanding Field Service Actions. Please ensure they are completed.
Page 1 of 2
Extended Period Maintenance
Brake system Every 2 years - Renew - brake fluid (LTS 12 154 4)
Air conditioning Every 3 years - Check temperature at the evaporator outlet tube. Check air conditioning
lines for damage and leaks
(LTS 34 619 1) (TSB 67/2002)
Cooling system Every 10 years - Drain, flush and refill with Super Plus
(LTS 24 122 4)
Camshaft drive belt Every 125 000 miles/10 years - Renew (LTS 21 304 9)
Auxiliary drive belts Every 125 000 miles/10 years - Renew (LTS 21 567 5)
Extra Services and Additional Offers * (optional - upon customer request / charged seperately)
Interior filter replacement Odour filter / Odour filter plus - remove and install.
(LTS 34 350 1)
AC maintenance package Air Conditioning (A.C.) system check. Apply A.C. cleaner to air distribution system.
(LTS 54 552 4)
Odour filter plus Upgrade odour filter to odour filter plus (LTS 34 350 1)
Test Drive
Test drive Perform test drive after routine service
Page 2 of 2
Note there is a TSB regarding the fuel pump remaining on and draining the battery, if the problem occurs.
Mk3 Focus Titanium X, 1.6 Ecoboost 150ps + Bluefin Remap
Candy Red
Appearance Pack
18" 5 Spoke Alloy Wheels
Manual 6-speed gearbox,,,
cuke2u is offline
