Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2012 Ford Focus Scheduled Maintenance
Old 07-16-2011, 01:03 AM   #4
LiquidGreyZX5
LiquidGreyZX5's Avatar
Fan#: 35544
What I Drive: 2012 Ingot Silver Metallic Titanium
FF Reputation: 1 LiquidGreyZX5 Good Standing Member
Originally Posted by DrkKnight614 View Post
Posted via FF Mobile Technically I guess. I would still check my oil once in a while and depending on your driving Id probably still change the oil before 10k, especially if you are in a lot of stop and go traffic or running to the store etc a lot. Keep an eye on other fluids too and obviously tires, and clean battery terminals. The air filter is a no change filter, the transmission is dry, so no fluid there. And your belt is actually a chain. So yes technically a lot of the tune up stuff youd normally do pretty much should last a really long time.
The automatic is "fill for life" and has a 150k interval as does the manual. You should replace the air filter every 30k. It's all on pg 388 of owner's manual.
LiquidGreyZX5 is offline
