Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Manual trans in 08-11
Old 07-15-2011, 01:52 PM   #50
StangGTT
StangGTT's Avatar
Fan#: 79886
What I Drive: 2012 Focus SE, 2000 Mustang GT
Points 1,371, Level 20
Points: 1,371, Level: 20 Points: 1,371, Level: 20 Points: 1,371, Level: 20
Level Up 72% Completed
FF Reputation: 1 StangGTT Good Standing Member
Originally Posted by Quanny View Post
Its quite possible that i did the damage to it, but there's some factors to take into consideration though... (This is about automatic trans)
The first 2008 i owned, this was the daily rental, it was at 42,000 kilometers, owned it almost 2 weeks, the motor started revving higher than normal, put it in park, and bam, it was locked in every gear, would not move at all... (found out later the planetary gears blew up) (this is also the time i found out about the little shifter side button that turns overdrive off and i had just started using it)
The second 2008 i owned, this one was the off lease, i got it at 40,000 kilometers, owned it for almost 2 years, i never touched that overdrive button until about the last week before the trans blew up, this time it was at 115,000 kilometers, the trans was grinding like hell, had no reverse, forward gears worked still but it kept engaging and disengaging while driving...
This second 2008 was not a cheap repair bill, it was $3000, (some bushing let go and all the gears got chewed up) and the car still had issues, (idling issues, electrical issues, radio control issues, suspension issue where it would eat the front drivers side tire rapidly) so i traded that one in for the 2010...
Both instances it seems like it happened soon after using the overdrive switch, that being said, im never using that bloody switch ever again, and i believe its the culprit somewhere around the line..
My guess is that wasn't that you pushed the button so much as what you did afterwards. lol Just a guess
Plus, I was really referring to the obviously younger dude that has destroyed three manual transmissions with a stock engine. I still have no idea how one could do that in such a new car. Unless it was a competition car or something.
2000 Mustang GT turbocharged
2012 Focus SE Hatch
2008 Lincoln MKX
SOLD:#013 2010 Focus SES, 2004 Mazda 6s and 2003 SVTF #1496
StangGTT is offline
