Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Sound System Install
Old 07-09-2011, 07:11 PM   #29
mattlqx
mattlqx's Avatar
Fan#: 87201
What I Drive: '12 SE 5-dr MT Yellow, '13 Boss 302
FF Reputation: 1 mattlqx Good Standing Member
Just installed F+R speakers in mine... It's pretty straight forward.
I found these instructions on another forum post. Reprinted here for permanence.
Front doors:
1. Use pick to remove screw cap cover behind door handle.
2. Unscrew (1) T-20 torx behind screw cap just removed.
3. Use PRT to unclip side trim around window switch panel.
4. Unplug window switch panel and remove.
5. Unscrew (2) T-20 torx from behind the panel just removed.
6. Unscrew (1) T-20 torx located on the side of the door panel.
7. Use PRT to unclip red reflector lens.
8. Unscrew (1) T-20 torx from behind the panel just removed.
9. Use PRT to unclip door panel, unplug and remove.
10. Unscrew (3) T-27 torx securing the speaker, unplug and
remove.
Rear Doors:
3. Use PRT to unclip window switch panel, unplug and remove.
4. Unscrew (2) T-2 0 tor x behi nd th e panel just removed.
5. Use PRT to unclip the door panel, unplug and remove.
6. Unscrew (3) 7mm bolts securing the speaker, unplug and
remove.
Kickers in the front... match the door paint. ;)
mattlqx is offline
