Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2012 focus select shift
Old 07-05-2011, 07:47 AM   #5
86524
Registered User
Fan#: 86524
What I Drive: 2012 Silver Titanium HB
Points 2,199, Level 28
Points: 2,199, Level: 28 Points: 2,199, Level: 28 Points: 2,199, Level: 28
Level Up 33% Completed
Level up: 33% Level up: 33% Level up: 33%
FF Reputation: 1 86524 Good Standing Member
From my experience, it behaves as follows:
  • Will not switch to the 6th gear
  • Computer changes to a more aggressive shifting mode as others have described above
  • If you shift with the buttons, you can not go back to computer shifting unless you move the gear shift lever back into D first
  • Computer will try to anticipate your acceleration demands and hold RPMs accordingly
  • Computer will use engine braking (downshifts) when you apply the brakes
86524 is offline
