Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - A/C Questions before I take it in...
Old 07-02-2011, 01:39 PM   #2
USARice
USARice's Avatar
Fan#: 56127
What I Drive: 2005 Silver ST, DD and AutoX
Points 2,541, Level 30
Points: 2,541, Level: 30 Points: 2,541, Level: 30 Points: 2,541, Level: 30
Level Up 61% Completed
FF Reputation: 1 USARice Good Standing Member
Buy-Sell-Trade Rating: (4)
57 Views and nobody knows if the fans are supposed to turn on with the A/C? Ugh.
More info if it helps.
1) I have now either unplugged or swapped out ever single relay, fuse, or diode related to the A/C system. Unplugging any of them had no effect at all in the way the system operated until I got to the inside fuse for the A/C Switch/Instrumentation.
2)The idle does not increase as it should when I turn the A/C on. It should fluctuate in time with turning the A/C on an off and as such does not increase air pressure either with cycling the system. The RECIRC switch does increase air pressure.
3)Turning to Defrost does not engage A/C clutch as it should.
Like I said before, it's like the car doesn't even know the A/C is on. To me that makes it seem like it's not a compressor problem because the other signs of the A/C being on aren't there.
And then there's the whole thing with the blower but I found a guy who'll sell me a blower and new Vent Control Cable for $45 so at least I'll get those parts fixed even though they aren't the source of the problem.
No, my avvy isn't a B&W photo....meet Jaz, the car that makes any pic look monochromatic!
USARice is offline
