Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - tczx3's complete how-to on front wheel bearing replacement
Old 06-26-2011, 10:45 PM   #18
Fan#: 39510
What I Drive: 2007 Focus SE
FF Reputation: 1 rsvp9146 Good Standing Member
Just finished doing this one today. Thanks for the writeup. In my case, I also found out that a CV joint had gone bad, so I replaced the axle at the same time. Some tips..
Soak the LCA pinch bolt with Kroil or PB blaster and let it sit before removing
Remove the LCA bolt BEFORE the strut pinch bolt. Once the bolt is out, use a prybar to carefully pop the LCA from the knuckle. This took more time than anything.
Put the new wheel bearing in the freezer overnight to shrink it. It just slid into the knuckle in my case.
Check your wheel hub for straightness using a dial indicator before removal. I suspected mine was slightly bent when i noticed that the inboard brake pad wore at an angle and I had developed a pulsing brake pedal. Sure enough, warped rotor and bent wheel hub face.
So, for me, it was
new axle assembly
new wheel hub and bearing
new brake rotor
new brake pads
rsvp9146 is offline
