Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 04 Ford Focus ZTS 2.3L auto transmission problems
Old 06-24-2011, 12:49 PM   #3
godschld7777
Fan#: 87105
What I Drive: 2004 Ford Focus ZTS 2.3L Drk Gray
Points 385, Level 7
Points: 385, Level: 7 Points: 385, Level: 7 Points: 385, Level: 7
Level Up 70% Completed
FF Reputation: 1 godschld7777 Good Standing Member
When my son bought the car it only had 82000 miles on it. When the transmission started messing up after two days and the service engine light came up with a "Shift Solenoid D stuck on" code we dropped the pan and replaced that solenoid with a new one. We then replaced the gasket and put in new fluid. When that did not fix it, I decided for us to drop the pan again and switch around some of the larger identical solenoids to see if the symptoms changed at all but they did not. Before doing this the fluid level was fine and there was not metal shavings in the pan or anything. I hope I answered your question. Yes his car has the same transmission as yours that was mentioned and they are having a lot of problems out of that transmission from what I have seen.
godschld7777 is offline
