Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 04 Ford Focus ZTS 2.3L auto transmission problems
Old 06-24-2011, 11:04 AM   #1
godschld7777
Fan#: 87105
What I Drive: 2004 Ford Focus ZTS 2.3L Drk Gray
Points 385, Level 7
Points: 385, Level: 7 Points: 385, Level: 7 Points: 385, Level: 7
Level Up 70% Completed
FF Reputation: 1 godschld7777 Good Standing Member
My son has a 04 Ford Focus ZTS 2.3L with 90000 miles on it that the automatic transmission started going out two days after he bought it. We are trying to figure out for sure if it is something mechanical inside or electronic like a solenoid. The first symptoms were that the vehicle could go into first gear just fine then the RPMs get high so you have to hold back and then it finally switches into what we think is 3rd gear, but then never goes into overdrive. The overdrive off light will sometimes begin flashing.
The code that keeps returning is Shift Solenoid D stuck on. We have changed out the solenoid and even switched some of the solenoids around to see if symptoms changed to other gears and they did not. The car has been driven like this by my son for about 8 months cause no one can afford to fix it right now.
About two months ago the reverse began going out also. Sometimes the reverse works but when it does the entire car shutters. The part that is confusing me is that last night my son called me and said that he needed me to come and pick him up cause his car seemed like it didn’t have any power. My husband went with me and I drove my son’s car home and discovered that it now feels like it was not shifting out of 1st and engaging in 3rd gear now. While driving it I decided to try turning the overdrive off and see what happens and when I did it shifted into 3rd again. This is really weird cause it seems like if this problem is mechanical like a gear band, that turning off the overdrive would not have changed the fact that it wouldn’t shift out of 1st. I have tried this before with the 1st to 2nd and turning off the overdrive doesn’t help that. Sorry this is so long, but if someone can give some advice I would really appreciate it.
godschld7777 is offline
