Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Highway lane drifting
Old 06-21-2011, 12:49 PM   #10
herbz
Fan#: 84909
What I Drive: 2012 SE Hatch 5MT Sterling Grey
Points 8,470, Level 62
Points: 8,470, Level: 62 Points: 8,470, Level: 62 Points: 8,470, Level: 62
Level Up 7% Completed
FF Reputation: 1 herbz Good Standing Member
Originally Posted by brewslayer View Post
I'm kinda glad I'm not the only one! Mine does it too & it's going back to the dealer on Friday. It's definiately something in the electric power steering because it doesn't do it all the time. It seems to start happening about a half hour or more into a long drive. The steering seems to lock in one position and when you go to move the wheel (either way) to make a slight adjustment, it resists until you put enough force into it to, and then it moves too much sending you to towards the other lane, it immmediately locks into that position and you can't make a minor adjustment to get back to center. You end up zigzaging in your lane for miles and miles. It's exhausting! We went on 1200 mile trip this weekend and had to change drivers every hour or so because of this. We pulled off at at rest area and I pulled the fuse for the steering module and it actually steered perfect (better than normal) for about a half hour and then it started up again. With my luck it won't do it when I take it to the dealer and they'll think I'm nuts!
Found this which is the likely culprit:
http://media.ford.com/images/10031/EPAS_MKS.pdf
Wonder if it can be disabled.
herbz is offline
