Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Highway lane drifting
Old 06-21-2011, 11:21 AM   #8
Wontfinishlast
Wontfinishlast's Avatar
Fan#: 65496
What I Drive: 2012 Sterling Grey Focus Hatch Ti
FF Reputation: 1 Wontfinishlast Good Standing Member
Originally Posted by Jazzdog View Post
The EPAS steering gear has drift/pull compensation that is intended to mitigate some of this. Most roads have a crown so driving down a 2 lane road w/ a crown your vehicle will drift to the right, same thing in left lane of a highway.
Next time you sense the condition take note of the road crown to see if that explains what is happening. Switch lanes if you are on freeway to see if that changes condition. The drift/pull compensation should sense the slight steering input and null it out so you don't feel the pull on the wheel but only to an extent. Check your tire pressures to make sure that is not it, can also swap LF & RF tires to see if that resolves issue, tire conicity (one side bigger diam than other) can also cause a pull.
I'm not sure its alignment out youre pressure our uneven diameter if the car is pulling left and right... Its probably just more sensitive than youre used to. I'd give it more time so you and the car are more used to each other. If the problem persists then sew if the dealer can reprogram the EPAS.
2012 Ford Focus Titanium Hatchback: Sterling Grey/Machined and painted wheels/Moon roof/Titanium premium package/Winter package
Ordered 5/2/11, Built 6/15/11, Picked up 6/24/11
Wontfinishlast is offline
