Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - FSWerks Cool-Flo Intake Installation Problems
Old 06-19-2011, 10:14 AM   #1
lacole725
Fan#: 85112
What I Drive: 2010 Ingot Silver Focus SE Sedan
Points 4,438, Level 42
Points: 4,438, Level: 42 Points: 4,438, Level: 42 Points: 4,438, Level: 42
Level Up 44% Completed
FF Reputation: 3 lacole725 Good Standing Member
I need some help. I attempted to install the FSWerks Cool-Flo Intake yesterday morning on my 2010 Sedan. Once I got everything taken off, I started the installation. The first problem I had was the MAF sensor housing was not big enough. It looked like is had some extra paint or slag in it, so I had to find something the file it out to make the hole bigger. Once I got that done, I attached the filter and tried sliding it into the car. In all the pictures I had seen, I never saw any lines below where the airbox sits. I think they are transmission cooler lines or something, but I managed to snake around them.
Now for the big problem. When I tried lining up the intake tube to the throttle body, is was extremely off center. I would have to bring the tube upwards and tilt it in an awkward position. To make it worse, the throttle body is smaller than the intake tube. The supplied silicone couplers are 3" in diameter, so it was too big for my 2.75" throttle body. I tried attaching the coupler to the throttle body as best I could then sliding the tube in and attaching that. I was trying to get it as tight as possible, then the hose clamp broke. After finding a thicker one somewhere, I resumed. The rubber mount that is screwed into the car for the intake to sit on is nowhere near the intake bracket. I had to pull the intake and mount towards each other then install the nut. I thought it looked ok and that it would work. The other problem I had was with the MAF sensor when trying to plug it in. It was extremely short, like more than anyone else had said. I finally got it to reach and plug in, but it looks stupid.
So after finally installing everything, I drove it down the road a couple times and everything seemed to be ok. The only thing I noticed was my car made a farting noise from the intake everytime I turned it off. When my girlfriend got home, we went to my cousin's cookout at his home about 45 minutes away. When I got there and pulled into the yard, I heard a whistling or sucking sound. I thought it sounded like air, so I checked it before I left. Turns out the coupler slipped off the throttle body and was sucking air in. I asked my cousin for a screwdriver and he held the tube over while I retightened the clamp. When I got done, we sat there and watched the tube slide right back off again because the mount was pulling it one direction and the coupler was too big to begin with. I made it to the auto store after cutting out at a red light one time and found a really thick hose clamp like the other one I had put on earlier. I tightened it up pretty good and I made it home without anymore problems.
Has anyone else had this kind of problem and how did you fix it? I think that if I find a 2.75" to 3" adapter hose it will fix that problem. Then if I drill a new hole for the mount to sit in, it will fix the alignment issue. Does that sound about right?
You can see how far away the mount is and how far stretched the MAF Sensor is.
Different angle of how far away the mount is from the bracket. I ended up unscrewing it some to give me a little more leverage.
How I ended up fixing the coupler. These clamps are considerably stronger than the flimsy ones FSWerks sent.
Adam
lacole725 is offline
