Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - From stock 2001 S2 to new 450hp+
Old 06-12-2011, 08:35 AM   #290
Mother Focus
Mother Focus's Avatar
Fan#: 73292
What I Drive: 2001 Money Pit
Points 4,667, Level 43
Points: 4,667, Level: 43 Points: 4,667, Level: 43 Points: 4,667, Level: 43
Level Up 59% Completed
Level up: 59% Level up: 59% Level up: 59%
FF Reputation: 13 Mother Focus Great Standing Member
Buy-Sell-Trade Rating: (9)
Originally Posted by 1turbofocus View Post
From what I am seeing it looks like some trash went though them , there is very little clearance on the cams and even a hair will do what your seeing , grit of sand , metal from machining
The biggest mistake I see people make when I see this and I have seen it a lot is they do head work , porting , surface etc and dont pull the oil passage plugs out and clean the head throughly and there is 6 plugs to pull out of you cannot clean the head throughly
Tom
Actually to prime the oil pump took a bit longer than I expected, it is a good possibility, the head may be saved not sure about the cams though.
Quick question, after installing a Torsen and having the 2 front tires in the air if you spin one manually (in neutral), does the other wheel turns in the opposite direction or they both move freely regardless like an open diff. Read a bunch and still not sure, it should work as an open diff until torque is applied unless preloaded (shimming)?
PTE 6262CEA
Pump Gas 385whp 319wtq
Race Gas 551whp 439wtq
Tuned by
Mother Focus is offline
