Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Sound System Install
Old 06-10-2011, 09:31 AM   #22
HammerStriker
HammerStriker's Avatar
Fan#: 86553
What I Drive: 2012 Ignot Silver Hatchback SEL
Points 1,476, Level 21
Points: 1,476, Level: 21 Points: 1,476, Level: 21 Points: 1,476, Level: 21
Level Up 76% Completed
FF Reputation: 1 HammerStriker Good Standing Member
I finally got a chance to do some measuring. The existing subwoofer box has .37 cu. ft. of sealed air space. So the existing box is not large enough to accommodate a 10" sub even though one would physically fit. I can make a box fit into the factory spot that will have .6 cu. ft. with a top mounting depth of 3.125" to accommodate most shallow mount 10” subs.
I just don’t know if all the work will be worth adding it into the factory system. So if this is gonna happen, I need to start looking into RMS ratings, signal processors, mono amps, capacitors… Oh crap, here we go again!!
HammerStriker is offline
