Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - anyone have pics of timing belt tensioner after installed and engine ran?
Old 06-08-2011, 12:18 PM   #9
duc450
duc450's Avatar
Fan#: 10651
What I Drive: 2004 Ford Focus SVT CD Silver
Points 1,557, Level 22
Points: 1,557, Level: 22 Points: 1,557, Level: 22 Points: 1,557, Level: 22
Level Up 57% Completed
Level up: 57% Level up: 57% Level up: 57%
FF Reputation: 4 duc450 Good Standing Member
how far off the mark does it get? Like I said mine is about an inch away from the window. Are you running the Gates tensioner? Cause I swapped from the Gates back to the stock Ford and the Ford wasn't off nearly as much as the Gates, even though my Ford one had the miles on it and the Gates one was used, which could explain why in itself. But I put the Gates back on for piece of mind cause it was new. Thanks again for all the opinions, if anyone else can keep adding to this I'd appreciate it.
"If you ain't moving fast enough your costing me money and if your costing me money you ain't moving fast enough." -"The Machine"-
duc450 is offline
